float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Dec 02, 2003 3:42 pm
To get slack in the belt, you'll need to loosen the tensioner up. To do that you'll need a socket and an allen wrench. On the left side of the motor, in the front, below the cam gears, there is a small round pully. That is the tentioner. Loosen the bolt in the middle and then use an appropriate sized allen wrench and rotate the tentioner until the belt is loose enough to remove it. As for the timing, I just made sure and set the motor at TDC on the compression stroke for the #1 cylnder, and then lined up the dots. I Only remember one dot on each gear, so I'm lost there. Good luck!
