RARZ wrote:I only have 84k miles on it, So it has a new water pump and belt, after looking deeper into the noise. It is really sounding like the idler pulley right above the water outlet. Is it acceptable to replace just the pulley on the auto tensioner? If so I will buy the timing belt kit from napa (where I work) it come with the belt 3 pulleys and the 3 seals.
Also I talked to nissan, they have not heard the car but they are saying it could be vtc sprocket? is that just bull s***?
It is acceptable to replace the pulleys. The pulley bearing is what goes on the tensioner. Definitely replace the seals as well. If it were me (note: I REALLY like my car and don't want the engine not to blow up), I would replace the pulley studs for both idlers with Ramey studs. (Notice: I have now said this twice! hmmm, wonder why?). Link =>
http://www.z1motorsports.com/product_in ... ts_id=2939
I would also swap out the belt at the same time. Might as well restart the clock with an OEM belt. Also, make sure your mechanic KNOWS how to do this change. Many mechanics will use the references on the backplate to set the cams and belts. On this motor, it is dead wrong. Use the lines on the belt to the cams and crank, ONLY!
Also, be prepared to buy a new crank sprocket when the front main is changed. They tend to get rusted on and need to be cut off. Then, you will need a new crank sprocket and a new rear crank sprocket washer.
Last, VTC. While I have heard the springs give out and make a hell of a racket, the VTC sprocket itself usually fails by leaking oil. You may need to change the springs and o rings for the VTC. I would anyway while I was in there as well as a thermostat if that hasn't been done already.
