float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sat Mar 06, 2010 9:18 pm
If you replaced the spring in the tensioner, then when you loosen up the bolt after you put the new belt on, then the tension should be correct. Just tighten the bolt back up.
