Timing belt
fabbio25
Car: 2014 Evo MR
1990 Z32 TT
Hello All,
I was told by a mechanic that a busted timing belt would destroy the engine on a z32. Any truth to this. I thought the engine was freewheeling on these cars.
Phil1996
Car: NISSAN 300ZX TWINTURBO 1996
Yes it's true because a part of the engine still moves when other parts stop to work.
The main problem when the timing belt brokes is the valves, because they stay open when the piston is still running!
Hope this helps !
Phil
vitaminZ
Car: 1990 Nissan 300ZX
Yes, but a mechanic will also tell you this to make $$$ off your a** by scaring you..
based on how many kms you have and how you drive the car will exactly know where your at
xclusivez32
Car: 1990 300zx 2 seater limo
tt engine build
2004 gmc serria
its happened to me under no load it bent all but 2 valves, they are interferance engines. makes a nasty sound too.
fabbio25
Car: 2014 Evo MR
1990 Z32 TT
Obviously a busted belt will make your car immobile but i didnt think it would do any damage to your engine. Being a freewheeling engine I thought that valves would not collide with pistons if the belt broke.
labcoatmonkey
Car: 1991 300zx JDM TT I miss u 01 alty
there will be interference, its important to do the 60K maintenance and the 120k. Beats sitting on the side of the road looking into your non-existent wallet =P
