Chillin014 »
https://forums.nicoclub.com/chillin014-u134592.html
Fri Oct 02, 2009 11:16 am
I'm in the process of changing the water pump this weekend. I'm not in a huge rush but damn I've had to take apart so much more than I expected. All the drivebelts, timing covers, pulley, radiator, etc.
It looks like I'm going to have to buy some extended allen wrench to remove the coolant logs and get the left timing cover off.
My only question is if you guys are just using the gasket or using silicone sealant for the water pump. I got a gasket with the pump but the FSM says to use sealant. I think I'm going to go with the gasket, I hate messing with sealant.
