timing belt
General discussion area for the L30-chassis Altima
mikehonda
Car: dakota
99 altima timing belt replace 78,000 miles already over due never did one on this car am i looking at a project?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Unless I'm mistaken, your car has a chain, and not a belt.
As far as I know, timing chains are pretty much maintenance free...but I've never owned a car with a chain long enough to have to deal with that.
I know the KA had issues with plastic guides, but I imagine that was resolved by 99.
nismo96ka
yea the altima is a chain....only motors i know of that nissan uses a timing belt on are the 3.3 and 3.0 liter SOHC motor.... maybe some older stuff idk.
Chimchim
Car: 97 d21 4x4
That is a chain and unless the front cover o-rings are leaking or the tentioner and guides are noisy leave it alone this is not a project you want to get into with out experience and a lift. you might get a little rattle from the top of the motor towards the front. this is the top guide and it makes noise remove the valve cover and remove guide dont replace they dont make the part and at the dealer we would always remove it if the cover was off any way. make sure to use nissan red rtv (looks orange) to reseal with new gasket.
l31nismo
Car: 2002 Nissan Altima SE Nismo 3.5 5spd MT
2005 Nissan Sentra SE-R Spec-V
The only time you need to replace a chain is if it, jumped timing, or the tensioner or guides are shot in this case you will hear a lot of noise from the front cover.
94ALTIMAGLE
Car: 94 altima gle
well the misister us correct. your car has chain. i had to do my 94 gle 2.4l dohc.the parts only cost 150, and i wound up spending over 1k with labor. if you want to drop the motor out, its a project. my advice send it your local mechanic.
but thats just me.
late
mikehonda wrote:99 altima timing belt replace 78,000 miles already over due never did one on this car am i looking at a project?
IndyG20
the
l31nismo wrote:The only time you need to replace a chain is if it, jumped timing, or the tensioner or guides are shot in this case you will hear a lot of noise from the front cover.
guide does not matter, as a matter of fact, most people just take them off and leave them off when they break. it causes annoying noise, but is a non-vital part.
Return to “2nd Generation Altima Sedan (1998-2001)”
