Mike2me »
https://forums.nicoclub.com/mike2me-u154107.html
Sat May 22, 2010 1:53 pm
My son and I just completed our first (and last) project Z32 with 136K miles that I picked up in Jan from my neighbor. It had not been moved or started in 5 years. We replaced all the necessary upper half componets, timing belt, cam seals crank seals, lifters and clutch assembly and had it on the road last weekend running great for some 50 miles on three or four test drives.The next day it died 100 yards from the garage, Code 34 (detonation Sensor) and I was not sure of what that monitored. The engine would crank but something about the engine rotation sounded different. Later after trying again to start it and wondering why it sounded different I heard the clunk. I was pretty confident what that meant and now the different sound when it was cranking made sense; the timing belt probably spun and our valves were out of sequence so the engine was not having to overcome the compession in at least some of the cylinders.
We just finished gaining access and taking off the timing covers and sure enough the belt was very loose on the right side of the block due to a mistake in our failure to set the autotensioner correctly.
I'm not sure how far any of the cams spund but because we heard components come into contact at the last engine crank I decided we'd move the crank backwards to it's reference point and we did verifiy that the #1 cyl did travel to the top of its stoke. The right side intake and exhause cams were somewhat close to their marks (but the timing belt white lines were not) so we went ahead and move the right side cams an inch or more to line them up on their marks. We pressurized the #1 cyl and found no leaks so we belive we're set on TDC on the #1 cylinder but we're not positive, the crank could be 180 degrees out. While rotating the crank thru by hand it stops (somethings hitting internally) exactly 2 inches into the crank travel.
So not knowing which cams actaully spun and how far they moved out of sequence, I'm wondering if someone can assist us and guide us through with how to find our timing. The intake plentum and valve covers are still on, and although we can certainly take them off, but I'm only confident enough that I'll be able to verify that the right side intake cam (valves) and exhaust cam are alligned to TDC. I'll have no clue how to dertermine if the crank is correct or 180 degrees out. Any Help?
