Timing belt/ sparkplugs?
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
Do I really need to remove the sparkplugs when installing my timing belt??
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Honestly don't recall removing mine when I replaced my water pump, tensioner, accessory belts, front oil seals, etc. a few years ago. Replaced 'em when I pulled then plenum to replace all six injectors, both PCV valves, the EGR valve, etc. and to do the throttle body heating delete a few months later.
robomatic12
Car: 1990 300ZX TT
Not necessary, just helps you rotate the crank easier due to the lack of compression.
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Thank You guys for replying!!
