Timing belt rubbing problem!! please help!
icemhan_21
Car: 1996 240sx
So i swapped this ca18det into my s13 and i just got it running and the only problem is that the timing belt is rubbing on the timing belt cover. I have adjusted the belt countless times and putting it very far back on the pulleys and tensioners but for some reason after about a min of it running, it suddenly would rub against the timing belt cover again i don't really know what i have been doing wrong. The belt is brand new. Please help me as i have been waiting to drive this car for so long but i still can't because this problem is holding me back!
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
check out your FAQ. I would think your belt guide down by the crank pulley isnt in place, or not in place properly.
mbmbmb23
Do you have the metal protective ring that goes behind the crank pulley gear installed?
icemhan_21
Car: 1996 240sx
ca18detgabby wrote:check out your FAQ. I would think your belt guide down by the crank pulley isnt in place, or not in place properly.
i dont think that i saw any guide that you guys are saying. anybody got a pic of it?
is it on this picture?
Modified by icemhan_21 at 8:58 PM 11/15/2009
aaronscomp
Car: s13
wen i first turned my ca18det over the front cover shreded the belt i had to replace it make sure u have like all the bolts in the front cover and they are tight
icemhan_21
Car: 1996 240sx
ok i just now found what im missing! i dont have this pieces circled red on the picture below. anybody has one for sale? or can i just use a big spacer to replace this? oh and i also got an rb25 sitting in my garage so can i just use the one from the rb25 since these motors are basically the same?
Modified by icemhan_21 at 9:34 PM 11/15/2009
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
I know you couldn't use a CA20 one.. but an RB one might be the same diameters. Definitely worth a try, and definitely the cause of your problem.
float_6969
I seriously doubt they are the same diameter. Just go order them from Nissan.
ca18detgabby
03 Infiniti G35
float_6969 wrote:I seriously doubt they are the same diameter. Just go order them from Nissan.
word.
a CA18DE one should work too I would think. I doubt they are that expensive anyway.
float_6969
Yup, same stuff as a Pulsar.
icemhan_21
Car: 1996 240sx
thanks for all your help guys! i got it fixed!! i used the one on my rb and it sure does fit!
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
better be the same for pulsars... i put those in my det block from my de block... haha!!
