hey guys i just put a new timing belt on my Z and the exhaust and the intake cam on the passenger side slipped a tooth and hit the top of the piston.
would you be able to tell/hear if the valves are broken or not if you turned the motor? my engine is pulled and i rotated it with a socket and ratchet and its perfectly timed. any input would be appreciated!
