timing belt replacement questions
J30inthe sun
Car: 1997 J30
I just received my 1997 Infiniti J30 timing belt kit from http://www.infinitipartsusa.com
This one:
http://www.trademotion.com/par...=3221
I noticed the kit does not come with the idlers. While I am having everything else replaced in there should I also replace these?
They look like # 21 in the image link below:
http://www.trademotion.com/par...gid=0
Also does anyone else have any recomendations on replacing anything else in this area while it is all apart so i can save some $ on the labor?
driverdriver
Car: NICO's longtime resident Canuck!!!
If your doing all that work, you should also replace your engine solenoids. They go with age.
yodawill2000
Car: 94 Infiniti J30
Uh Aren't the solenoids near the Valves ??Don't have to dig that deep for a T-Belt swap.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
You do get one idler bearing with the auto-tensioner.
Check the feel of the sealed bearings in your camshaft position sensor. Mine had dried out/were rough and they are a common size, but getting things apart without damaging the laser cut wheel inside is VERY risky/tricky.
Have the radiator and transmission cooler removed and cleaned, and maybe the transmission flushed with a filter change?
I don't know which solenoids driverdriver is referring to.
yodawill2000
I assumed he meant the Valve solenoids.Maybe I missed something.
J30inthe sun
Car: 1997 J30
I could not find any listing for "engine solenoid" at Infiniti Parts USA.
Could you be more specific?
Thanks in advance & thanks to everyones contribution to these forums, they are great, I have learned so much & am very grateful.
J30inthe sun
Car: 1997 J30
Whre is the "sealed bearings in your camshaft position sensor"?
I could only find this:
http://www.trademotion.com/par...id=55
Unfortunately there is not any diagram.
Thanks in advance!
J30inthe sun
Car: 1997 J30
Question to anybody that has changed their timing belt, did you replace the upper & lower idler pulleys which are not included in the "timing belt kit" from Infiniti parts USA?
Anyone know how many miles they are rated for?
I am at 107,000 mile on my 97 J30.
Thanks in advance!
GerryO
Car: 1993 J30t
Pearl White
Black Interior
J30inthe sun wrote:Question to anybody that has changed their timing belt, did you replace the upper & lower idler pulleys which are not included in the "timing belt kit" from Infiniti parts USA?
Re: (GerryO) 5:13 PM 8/4/2008
Where are the "sealed bearings in your camshaft position sensor"?
Thanks in advance!
Had I known about them I might have changed mine at about 168K when I did my timing belt, but like you say they aren't included in the kit and they are pretty expensive.
The camshaft position sensor is a $300+ part that has a laser cut wheel inside of it along with an optical sensor and the two sealed bearings. I got determined and opened mine to replace my rough/dried sealed bearings, but bent the laser cut wheel in the process. I managed to straighten it and things ran fine afterward. Later I specially modified a large bearing splitter tool to get things apart without damaging anything.
Mine is a '93 J30 and everything should be newer/better on your '97, plus your mileage is low too.
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
Thanks in advance!
i didnt do the entire timing belt kit...i just replaced the timing belt...however i did a few other things "while i was in there"...shouldve changed the solenoids too but i had soo many other things going on it didnt cross my mind... am at 110,000 on my 94...if they arent making any noises and are moving freely without restriction then i wouldnt worry about it...
coolyun_98
Car: 1993 J30 11,7000kM
You can replace the alternator if you want.
graydragon
Car: Infiniti J30
how long for an average do it yourselfer to change out the timing belt?
graydragon
Car: Infiniti J30
why change the alternater if its not broke.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
graydragon wrote:how long for an average do it yourselfer to change out the timing belt?
Unlike some other things in life the first time takes longer and 60K miles/about 10 years from now will probably seem like another first time (dreaming out loud), but I should still have all of the necessary tools (those made of metal, at least).
Well this could be the last timeThis could be the last timeMaybe the last timeI dont know. oh no. oh no
