datsunboy »
https://forums.nicoclub.com/datsunboy-u15035.html
Tue Jun 27, 2006 3:48 pm
my best advice to this would be to IGNORE the "number of teeth between...blah blah" COMPLETELY!
All you need to do, is line up all the pulleys/crank with the proper marks, and install the belt.
as "R34 gtr" said, the cam pulleys, wont want to sit lined up with the marks naturally, they will want to sit just off, so you will need to make sure they are held in position properly as you put the belt on.
If you do all this, then it should work perfect first time.If you start thinking about the number of teeth.....it will just get you confused.
