lilskyline240 »
https://forums.nicoclub.com/lilskyline240-u33468.html
Wed May 03, 2006 5:47 pm
Ok 2 days ago i went to do the timing belt/tensioner/waterpump on my 84 300zx turbo. Everything went smoothly TDC was esablished on cylinder 1 belt off, new belt on. Then the problem happened. while turning the drivers side cam with a wrench, the cam gear slipped on the belt because it wasnt tensioned enough. We were turning it to check to make sure nothing hit on the engine. So we put both Cam gears and crank sprocket back to where they are supposed to be and put the belt back on correctly again. Put everything back on all gaurds and pulleys and go to start the car and all it does is crank and crank but doesnt fire. Ive checked every single spark plug and they are wet with gas. Then i checked to make sure they all fired and they did when connected to the plug wire. Then i verified that all the timing marks are right on. when the car is in TDC for cylinders 1, and 6 all the marks line up correctly. The distributor lines up on cylinder 1 when it is in TDC for cylinder 1. Is there somethign im missing? When i try to start the car with the fuel pump disconnected the car stumbles and coughs but wont start. The second i reconnect the fuel pump the car wont even stumble, it just cranks and cranks and nothing happened. No valves are hitting either. I know the cylinders are/were flooded because there is a gas smell in my oil and the spark plugs were all covered with gas. So i cleaned them off and tried again. No change. Any help is appreciated.
thanksben
