Timing belt or chain in my Nissan 240SX SEConvertible?
Houli715
Car: Nissan 240SX SE Convertible
Hello, I have a 1992 Nissan 240SX SE Convertible. I am not sure if it has a timing belt, or if it is a timing chain? It has a 4 cylinder, 2.4 liter engine, RWD. I purchased it from a previous owner two years ago and am unsure which one it usually comes with. If anyone can clarify this for me I would appreciate it. Thanks!
Rex
Car: None
KA24DE has a timing chain, but there can be an issue with the upper guide and a "rattle". Worth looking into.
NICO's 240SX Tech Section
http://www.nicoclub.com/articles.php?id ... ?id=161703
Houli715
Ok thanks! I appreciate you clarifying this question for me. I of course have looked under the hood but did not see a belt, leaving me to believe it must be an internal chain. I used to drive a 1986 Nissan hard-body pickup truck with a 4 cylinder engine and it had a timing chain, which also led me to believe that my car would have a chain because of its similar engine.
Warped161
Car: 90 s13 the never ending project
the only real difference between those two motors is the throttle body. But yes timing chain.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
the upper timing chain guide if still in your ride..needs to be removed...if ya pop the valve cover off you will see it if ya have one..they break and do dmg on the way down into your oil sump....allso...take a look at your chain guides if thats not the issue...you might have one failing....hope this helps..good luck.
