Timing Belt noise
d356bud
Car: 1990 240sx w/ RB25DET
Well I have a squealing noise coming from the timing belt cover area. I didn't think I overtightened the belt, but I could be wrong. I replaced the belt with a Greddy. It only makes the noise when I run it for more than 20-30 minutes.
lazyboi444
Car: 240sx Hatchback
Check the clearance whether it may be rubbing somewhere...Or could be over tightened like you said...Either that or could the tension or idler be making the squealing...Somebody else chime in
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
+1 for lazyboi444
What kinda noise is it making? Its hard to tell.
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
My HKS Belt makes a Supercharged Squal noise. I think its a Little over tight, But thats were the tensioner locked in, I have not had any issues, I have not went back to re adjust it. Its not loud when driving mostly at idle, so i have not bothered with it. I have 24 track passes with it like that and a few hundred hwy miles, No issues.
240z4u
Car: '95 Nissan 240SX
rb25drag wrote:My HKS Belt makes a Supercharged Squal noise. I think its a Little over tight, But thats were the tensioner locked in, I have not had any issues, I have not went back to re adjust it. Its not loud when driving mostly at idle, so i have not bothered with it. I have 24 track passes with it like that and a few hundred hwy miles, No issues.
My greddy is silent, as was my stock belt, You should correct it next time you have it apart.
Evan
nizmo zilvia
I would fix the noise asap. It's making a noise for a reason and telling you that there is some thing is wrong. Just don't be mad later on when some thing breaks on you. Fix it!
StricNyne
i think i got a idler and tensioner brand new i would sell ya pretty cheap since they taking up space and i dont plan on building the spare motor ne time soon
d356bud
its not that loud, if you pop the hood you can hear it but if ur diving you can't
krayton
is your timing cover off?
i had that same problem. tightened just like fsm said 5 times.
put the cover back on, and i couldnt hear it anymore.
d356bud
the cover is on
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
d356bud wrote:Well I have a squealing noise coming from the timing belt cover area. I didn't think I overtightened the belt, but I could be wrong. I replaced the belt with a Greddy. It only makes the noise when I run it for more than 20-30 minutes.
id def pull it apart, when the belts off heat up the idler and tentioner, prob one or the other gone bad, there only like 55 fro both might as well replace them while its apart
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
in all seriousness. Either the idler pulley or tensioner pulley is going bad. same belt squeal happened to me and i didn't bother with it for 2 weeks. I took it out one day for some hard driving and the bolt to the tensioner snapped in half. Which caused my valves and pistons to make contact. Ordered a new motor. It's no joke my brother. Change that bish!
d356bud
Well I put new pulleys on it and I still have that noise. heres a vid that I shot with my phone:http://www.savefile.com/files/1801793
d356bud
anyone?
240z4u
Can i veiw that file with windows media?
Evan
d356bud
I believe Media Player Classic and Windows meadia player will work if u have th codec. As long as you have a codec for 3g2 files. I tried to put it on youtube but the audio conversion is really bad.
240z4u
d356bud wrote:I believe Media Player Classic and Windows meadia player will work if u have th codec. As long as you have a codec for 3g2 files. I tried to put it on youtube but the audio conversion is really bad.
Are you absolutely sure its your timing belt? Is it a metal on metal screech or a squeal?
I have not heard your vid, ill try it at home.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
240z4u wrote:Are you absolutely sure its your timing belt? Is it a metal on metal screech or a squeal?
Vid plays with Media Player Classic: Media Player Classic via AfterDawn.com
StricNyne
hey man u did both of em ?
SullivanRacing06
if ur hearing a metal on metal sound and youve already replaced BOTH of the t belt pulleys (idler, tentioner) then id pull the valve covers n check to se if a cam bearing lobe is shot, the part where the cam spins in the head, idk man sound weird
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
I thought the same thing until i had to take the cover off for something and noticed that the blue coating on the greddy belt was melted to my brand new pulleys. So i would readjust before your belt gets ate up
as far as the the squealing i would check to make sure a cover isnt rubbing somewhere espically the bottom one.
d356bud
so I assume u loosened the belt?
d356bud
I did change both of the pulleys, it doesn't sound like metal contact I dont think
mott6904
I took the belt off and wire wheeled the pulleys to get the belt material off then put back together and all seems fine. I just did this on saturday so time will tell if my belt needs replaced. I would say loosen the belt and see what the does.
