Brian VT »
https://forums.nicoclub.com/brian-vt-u268405.html
Tue Oct 04, 2016 6:24 am
Well I went with the Aisin kit (OEM I believe).
Here's the list of what I've got so far. Anything else I should replace while I'm in there? Front thermostat maybe?
Timing belt, tensioner bearing and spring, water pump with gasket, timing cover gasket, 2 Camshaft Seals, 2 Crankshaft Seals, coolant bypass hose.
