kbflip02 wrote:
in all honesty i dont recall seeing that particular part when we did the timing belt last month....ill look 2morrow when theres light but i might have an idea...about how long and thick is it?
Approximately, 6mm (radius, if it were a circle) x 5mm (depth) x 15mm (diameter, if it were a circle).
It's weird, I don't know where it could've come from, but the chances are most likely that it showed up after I took the starter out.
Did you (assuming you got the timing belt kit form
http://www.trademotion.com/par...=3221 ) install the 4 camshaft seals (13042-16V00), the crankshaft seal (13510-10Y10) and the 2 o-rings (13037-75T00)? Their picture
http://www.trademotion.com/sfi...8.jpg doesn't even show the o-rings (unless I missed it but I stared at this picture for a half hour looking). It looks like the camshaft seals go on both sides of the intake camshaft sprockets...somehow. But taking that apart worries me since everything is all in alignment now. I also don't see the crankshaft seal on the picture...so I have no clue about that.
I can't clearly figure out where they go and the manual doesn't give me a good explanation on how to do it...so I'm not all that comfortable with trying to use them. I figure it isn't that big of a waste if I don't use them...but if it's not too hard I would want to put the new ones in. Maybe these are more for people who are taking more apart than what I am doing?
Edit: Scratch that. There's no way I'm doing the Oil Seal for the crankshaft. I found it on EM-22, I am not interested in taking the oil pump out and the oil pan. I'm ready to put this thing back together...not take more apart.
I think I'm going to pass on the camshaft oil seals too. I'd have to go get a tool to put them in. I'm guessing two are behind the exhaust sprockets and two are behind the intake sprockets like in the picture on EM-22, under "Camshaft Oil Seal", except they just show the intake sprockets.
I'm still not sure where the two o-rings are supposed to go. Their description lingo doesn't match up with stuff in the manual. It should be easier to do this.
Modified by jertapper at 10:45 PM 6/14/2008
