Later today. 'll probably pop the top timing cover. Yes I know these are non interference motors. It's been 23 years since 1995 and the previous owner(s) had to change it at least once. Just been avoiding to do another timing belt job since I've got other peoples cars to do.NolimitZ32 wrote: ↑Thu Jun 14, 2018 1:58 pmLook at it this way: If it pops, your immaculate Z becomes a really pretty paperweight. So is it worth it? If you have the knowledge and experience to be able to look at the belt and tell if it needs changing than do that otherwise you should probably change it.
I was just asking if it's pretty urgent at 60k to change your timing belt.NolimitZ32 wrote: ↑Thu Jun 14, 2018 1:58 pmLook at it this way: If it pops, your immaculate Z becomes a really pretty paperweight. So is it worth it? If you have the knowledge and experience to be able to look at the belt and tell if it needs changing than do that otherwise you should probably change it.
Okay, well I just looked at the timing belt. I popped open the top timing cover. I didn't notice any cracks forming yet. I can even still see the smudgedwriting on the belt and the arrow indicator. Still says "Nissan" on it. Don't know if it's the actual belt from 1995 or someone replaced it with a newer OEM one. Thinking that it's already been 23 years since it left the factory, someone had to already change it. I'll look at it again in the next 15-25k miles.amc49 wrote: ↑Thu Jun 14, 2018 2:51 pmFYI, most timing belts changed material around '98-00 to begin to use hypalon in the belts and the typical change times then extended from 60K miles to 120K, the belt materials being much stronger. So, depends kinda on if somebody has changed it since the original one. May already have a much longer lasting one on it.
I’ll check again, maybe if my days off. First thing, I popped the top timing cover on the driver side and looked on the top of the timing belt to see if I was still able to read it, and it had smudged writing. Then looked on the teeth to see if it was cracked or ripping, and nothing. Flexed it quite a bit to see if it was loosed or stretched and felt okay. Also looked to see if the sides of the belt was degrading with white rope. I didn’t turn the crank to see if all around the timing belt was okay since I didn’t feel like lifting the car on my grassy hill driveway. I believe someone had to change it at least once since a 23 year old belt wouldn’t be lasted up to now.amc49 wrote: ↑Sun Jun 17, 2018 12:45 amIn my experience they strip teeth with zero warning and the belt will look perfect right up until it happens. There being absolutely no way to tell how old a belt is by simply looking at it commonly. Many will look almost new except for the missing teeth. Of course once they fray or crack it's past time to do it. Although they can break, they commonly don't and why so many people keep trying to start the cars and just tearing up an interference one more and more doing that.
If the starter starts suddenly sounding like it is cycling faster than normal on a non-starting engine with a rubber timing belt STOP! Your only warning there.
Yeah, I had a few people telling me this was an inter fear ace motor. I’ll try look again when I have time to spin the crank with he top timing cover open to inspect every part of the beltNolimitZ32 wrote: ↑Fri Jun 15, 2018 7:36 amThese engines ARE interference, that's why if the belt pops it results in catastrophic damage. On non-interference engines, its not a big deal.
Please read ALL what I typed....NolimitZ32 wrote: ↑Mon Jun 18, 2018 4:09 amLooking at the top of the belt will tell you nothing, as many have already mentioned sometimes the belts will go without warning. If you're going to inspect a the belt it needs to be done on the toothed side and along the edge, if you don;t know exactly what to look for then just staring at it is useless because you likely wont be able to tell.
Thanks
