Darius »
https://forums.nicoclub.com/darius-u5470.html
Thu Oct 19, 2006 3:07 am
I'm finally putting the engine together again and installed the timing belt last night. For some reason, the belt begins to walk towards the block after a couple of crankshaft rotations. I have HKS cams, an N1 oil pump, and a Z31 tensioner with stock RB25 spring. Can anyone give me some insight as to why this may be happening? Am I tensioning it too tight or too loose maybe? The FSM says "the timing belt must be tightened the right amount" OH, NO $HIT?!
I followed the procedure to rotate the belt twice and then tighten the nut, but every time I rotate the belt and let off pressure, the belt goes a little slack. Do I tension it to the tighter position as the belt rotates or the looser position as I let off the wrench to turn the crank?
