NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Jun 19, 2005 4:31 am
Steve the main reason I decided to do this online thing is my feable attempt to reduce the amount of hack work we recieve at the dealer after someone else hoses up a nissan/infiniti product. You would be suprised at what some people will do ,even independant shops, in trying to fix their cars.
As far as your tensioner goes rotate it clock wise till the spring hits the stud. the hex at that point will be between 12 and 3 at rest. Then continue rotating it till it is at about 9:00 sinch the nut down so it wont move back then install your belt. If you got the factory belt it will have painted lines on it 2 solid and one dotted . The dotted line goes on the passenger[right hand] cam gear,aligned with the dot on the gear, following the belt to the drivers side [left hand] you will find mark #2 , a solid line, place that on the dot on the gear for the left hand cam. then folow the belt down to mark # 3 and place that on the crank gears dot. No need to count the teeth if you follow those marks. once all is in place loosen the tensioner nut and it will spin into the belt and rest right around 7:00. Then adjust the tension as I mentioned in the other post. Note you may need to asist it to get the tension to the right place,like use your allen to turn the tensioner a bit into the belt then let it rest and do the adjustment. It depends on how strong the spring still is and how much build up is on the spring weather or not it will self adjust to the proper point.
