timing belt cover
matty
Car: 1990 Sil-40
so does nayone make a clear timing belt cover for the ca18det? i know trust makes em for the rb series,
i was trying to find one since i have a nice set of tomei cam pullys on the way.i dont wanna hide em behind the oem cover.
and when i remove the cam sensor, any tips or things to be aware of?
thanks guys
bentvalves
Car: 89 Silvia K's
I have tomei cam gears as well, and feel the same way as you do about them. So I chopped the intake side of the cam cover off.....cant do this on the other side cause of the CAS.
capowered240
Car: 90 240sx
What about getting one of those cas brackets from a RB motor.
matty
Car: 1990 Sil-40
come again?
matty
Car: 1990 Sil-40
does anyody knwo what the clear cam covers are made of?
is it some sort of high temp plastic?
matty
Car: 1990 Sil-40
and ide rather run without one then cut it up. im not sure how it would look.
got any pics?
rico05
Car: 1992 RMS13 w/ CA18DET
Sean's (NeedCAforS13) car:
I've seen RBs with a little bracket that mounts on the front and holds the CAS and nothing else. Don't know if it ould work for a CA though...or even who makes it...
matty
Car: 1990 Sil-40
is seans just cut in that pic?
it doesnt look that bad.
anybody else have pics of a setup like this?
and a pic of this rb cas holding bracket?
capowered240
Car: 90 240sx
Here is the pic of the bracket. I think it will fit. I was thinking of getting one.
bentvalves
Car: 89 Silvia K's
that was a full on cover at one point, just been chopped and massaged like I suggested.
**on second thought....??????
Modified by ks13 at 5:48 PM 10/9/2006
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
arent you guys worried about getting stuff behind the cover? i am not running my coilpack cover (misplaced the screws! kill me now!) and i have to shop vac out around the plugs before i can remove them because so much crap gets in there. i would be worried something would get around the crank gear and mess stuff up.
rico05
Hey, r34...shoot me your addy and I will send you my old coilpack cover screws if you want...
rico05 at tamu dot edu
r34 gtr
i would appreciate that so much. i swear i have no idea where they went. an unfortunate casualty from my most recent engine rebuild. ill shoot you an email here in a few.
float_6969
I used to keep mine on there after going standalone, but I've still got that gaping hole in the front so I figured it was a waste of weight so I haven't had it on for a long time. I haven't had any problems with anything getting caught in there. I've scrapped my hand a couple of times, but that's just me being stuid.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
Mine was cut...actually Sean cut mine. Before I sold the car.
