timing belt check?
qx4girl
Car: 1997 Infiniti QX4 4X4
My rig has 178,000 miles on it. I have no idea if timing belt has been done. Is there an inspection hole/plate or something I can easily remove with out tearing it all apart?
The dealer told me you can only check it by tearing it all apart and by then I should just do it.
I don't want to do it if I don't have too. It's no cheap, that's for sure.
Thanks again for all the help!
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
You dont "have" to do any maintenance item
But its just that.... maintenance...
I think the belt is 100 or 120k service
If your tight on money though I wouldnt worry about it now, pretend in your head someone did it already lol
wildpig
Car: 2003 BMW M3 Convertible
2004 Infiniti G35 Coupe
2002 Pathfinder SE 4x2
my old 97 pathy went 211k miles. I didn't replace the timing belt after I bought the car at 145k miles. So even assuming the guy before me did it at 100k or so that will still give well over 100k miles. And if he didn't, well, it made it to 211k on just the factory belt. Couldve gone more if i didn't wreck it ;(
ARKQX33V6
97 QX4 rated at 168 K Km or 100,000+miles. Changed mine at 170,000 km belt was still supple square and tensioners good. Inference fit motor, broken belt = lots of money to repair. vs. time and $700 for DIY or $1000 for dealer.
