Ronnie »
https://forums.nicoclub.com/ronnie-u9874.html
Wed Oct 22, 2003 12:46 am
I once have had a bad timing belt change from a dealer, they left the cover loose and bolts missing and also used the old screw driver trick to turn over the engine to get a new fan belt on that they claimed I needed and the old belt thy put in the trunk was cut off to save instalation time , a month later my vibration damper came loose on the flywheel pulley from being way to tight and I had to pull the radiador and at lot of bull to fix it myself, bottom line, I change my oil every 3000 with filter Im not harsh on the car , can I let the belt go to 90k.???? the engine is as steady as ever at Idle,I dont want another bad quicky job that who knows if a cigar butt or paper clip was left in the timming cover as well as a hamberger wrapper?
