Timing belt change gone bad!
danm30
Car: 91' Infiniti M30
ALright guys im new here and looking for a third opinion. I replaced my timing belt last night, but when i turned over i couldnt get a good start. now there are signs of life but im guesing timming is just wayyy off. I tried to find TDC by just turing the motor but that was a failure. Now im going to dismantle it all tommorow and check the belt make sure the marks on on the right areas. but before i give it another go i was going listen to some other M30's enthusiasts with what your past experiences are for making sure its all on spot and how you found top dead center since, well atleast on mine...there is no timing marks on the crank pulley. Thanks guys!!
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
its a pita, but keep spinning it over until the cams line up. the nissan motors ARE interference motors so if it is off to much youll end up bending some valves.
swimshark
driverdriver
Car: NICO's longtime resident Canuck!!!
danM30, I would also post your query in the 240sx forum. M30 owners are few and far between in this forum.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
danm30 wrote:ALright guys im new here and looking for a third opinion. I replaced my <A class=vglnk title="Link added by VigLink" href="http://shop.ebay.com/i.html?_nkw=timing+belt" rel=nofollow vglnk_1335476446168="3">timing belt</A> last night, but when i turned over i couldnt get a good start. now there are signs of life but im guesing timming is just wayyy off. I tried to find TDC by just turing the motor but that was a failure. Now im going to dismantle it all tommorow and check the belt make sure the marks on on the right areas. but before i give it another go i was going listen to some other M30's enthusiasts with what your past experiences are for making sure its all on spot and how you found top dead center since, well atleast on mine...there is no timing marks on the crank pulley. Thanks guys!!
Don't force anything and replace the crank pulley with one that has timing belt alignment marks on it.
