Timing belt change and bemt valve?
coolyun_98
Car: 1993 J30 11,7000kM
Hi:
I have a 93 J30 with 75k miles. Purchased last year as a used car.
Is it possible that a valve can be bent during timing belt replacement? when I replaced the belt, the passenger side intake cam rotated by about 60 degree. If the valve kinda KISSED the piston, will that cause enough damage to the valve?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If your camshaft is off by 60°, I can guarantee at the minimum you bent a valve.
coolyun_98
Seriously??? I am having a heart attack now.
I mean intake sprocket rotated 60 degree while the engine if off and timing belt is taken off.
The procket rotated wile I installed the belt....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
If you are not timed correctly on an interference engine, you will get interference. Pistons hitting valves is not good.
