sideways24d »
https://forums.nicoclub.com/sideways24d-u64505.html
Sat Sep 01, 2007 10:15 am
Two ways you can go about doing that. You can do what i did and time it by taking the cover off and looking at the cam positions. After the intake cam lifts off, take out the number one plug and put a straight piece of wire in the cylinder, rest it on the piston, and have someone turn the crank pulley till it gets to the top of the stroke by looking at the wire.
Or if you do not want to take off the cover, remove no. 1 plug and wire, have someone crank the car, and you put your finger over the hole. when you feel a big burst off air stop cranking, thats your compression stroke. put that wire in and back it off past tdc, then to tdc. Your on no.1 compression TDC.
