Timing and tuning question???
meet07
Car: 89 180sx rb25det
I use to have a oem RB25det series 1 with AEM tuned for 17psi. The engine ran lean one night and popped! So I have decided to replace that engine with a Neo. I know I could just rebuild the oem engine for the same price but I would like to start over with something a little different.
My question is I know the Neo had a compression ratio of 9:5:1 compared to the series 1 which is 9:0:1. With my tune, the car should at least fire up. But what I want to know is "Where can I safely set my timing at to get it to the tuner"? Is there some sort of equation I can go by? I would have to look to make sure but I believe my total timing was at 14 degrees. With That I was making 470whp
Thanks
ezb57e
Initial or total timing?
The initial timing might be 10-14 degrees.
It should certainly start and run at that.
meet07
Total timing.
RRRRB
Car: 98 RB powered S14
if your taking it to a tuner why are you so worried about it... dont beat it until its tuned.
Booztd 3
Car: 1990 Nissan 300ZX TT
Just getting it up and running and over to the tuner, leaving everything where its at while be fine
ezb57e
Total of 30 should be safe enough to drive.
