Driftkid3593 wrote:no check engin lights i have soild compression across the board. but as soon as u move the CAS the car WILL NOT run
Check the timing belt, it kinda sounds like you jumped a tooth. Compression will still be good if the belt jumped a tooth or two, it just may take a little more time to get to the correct number.
Can you give us a little more insight what happened so maybe we can help diagnose better? It is hard to help if we are trying to pull information out of you. Just saying moved CAS and stops running doesn't really tell us much. What are you doing with moving the CAS? Have you done any work recently? Have you checked injectors, do they ohm test between 10-14? Where you just driving down the road and it stopped? Was it running rough before it stopped running?
