WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Thu May 06, 2004 4:30 am
I haven't tuned the KA yet, but I have tuned several RB's. I made the most reliable power at 12.7/1 AFR's. It screamed at 13.5/1 AF while on alcohol. Another thing I recommend strongly
If you wany daily driver safe, I'd stay at high 11's. Just to compensate for heat soak of the IC and climate changes. Dan from UH runs 15 psi all day everyday and has for over a year now and makes 350 WHP with no problems at all. If you eliminate the knock your golden, but I'm sure your well aware already. I'm betting the KA will see 400 on all stock internals. I'm going to push mine until she blows as soon as I get the spare motor all done up. If the tuning is good, I wouldn't worry until over 20 psi, much more and the ring lands may have issues. The rods will hold forever as long as you stay under 7100 or so RPM.
I don't know where to start since you have no stock timing map to alter. I used the stock map of the RB since it was already a boost programed ECU.
Once you get over 5 psi your going to want to retard proportionally to boost, .5 is a good start like Pedro suggested.
I'm using the MSD BTM on my KA so I don't need any new maps. I've also never used the AEM system before, although I hear great things about it.
Not much help on the timing issue. Not to many guys have done standalone tuning on here. Building your timing map from scratch is a PITA. Start weak and progress.
Brian
