dogred »
https://forums.nicoclub.com/dogred-u134060.html
Mon Nov 08, 2010 3:08 pm
I just did my timing the other day and could not get it timed to 3 degrees BTDC like the manual and emissiond plate states. I could only get to 10 degress BTDC. Had the vaccum advance disconnected and plugged. Right now I am fulled advanced, it runs ok but on steep hills it sucks, lots of pinging, but I can go full throttle everywhere except on steep hills. Tried retarding it and the hill situation gets better but still pings but I cannot go full throttle anywhere without pinging.
Should I take off the front cover and water pump and recheck the timing chain, cam sprocket setup?
Is there any other way to help this situation out?
I believe the head on this motor has been removed at least once by the previous owner.
