ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Mon Apr 18, 2011 7:19 am
Before the ECU the engine must be in a physical condition of meeting the needs to be timed. The basic static timing of the engine must be met.
The ECU has many inputs, gas, MAF, static timing, barometric pressure, engine speed and load to name just a few.
The ECU is a dynamic device and through math and other algorithms sensing and switching tries to keep the combustion first off in order and tries to maintain perfect combustion burn rates as per the needs of the engine at all conditions.
The basic firing order is done pre ECU as is the basic timing. Advance and retard of timing is for the mechanical side to catch up to the electrical side of the timing issues. The mechanics of a rotating engine at various speeds can be determined but to have a spark at the exact time takes a lot of engineering, not only the mechanical aspects of fast and slow movement of large masses of pistons, valves and gears but the mating of induction of gases, induction of electron movement and then placing these actions and reactions into one machine to work at the most effective timing to create the bang of the cylinders at the right time.
There are many theories involved within the ECU, as there are within an internally combusted engine.
