drjohn »
https://forums.nicoclub.com/drjohn-u115.html
Fri Jan 24, 2003 12:28 pm
If you didn't have it on tdc #1 when you adjusted the tensioner you did a bad thing. The valve stems are thin on these engines and the valves bend easily. I suggest taking the plugs out and slowly turning the crank alittle and the cams alittle to get it on tdc #1 and the cams back to timing marks. Remove the dist cap and see where #1 fires, you have to look in the cap #1 doesn't fire right at #1 plug wire position. You may have to pull the heads to re-time it. If you can get all the pistons part way down in the cylinders this will allow you to turn the cams with less chance of bending valves. Remember turn slow and easy and stop at any resistance.
