ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Jun 24, 2011 9:23 am
Chris, QX4, 1997, 250,000 KM. 1978 Bronco, 400 Ci In, C6 transmission about 110,000 km but many idle hours and snow plowing hours with many times buried in mud and snow. When 2 yrs old drove with no oil in crankcase thanks to Ford dealer who forgot to add oil on an oil change. After 50 km or so engine very hot, checked and found no oil no oil filter, called dealer said they will warrant repairs. Bought oil and filter installed. Worked for another 18 years. I guess the no oil fiasco honed the engine good.
The QX4 is an OK vehicle, being the first for that model, it is built well but some design aspects are horrible. But after 14 years I'm used to the failings and just maintain it knowing its weak spots.
When the 3.5 came out, the HP was upped which was needed but fuel economy suffered a lot, my MPG highway is always 30-32 but only straight highway. That's 700-750 km a tank.
Transmission and transfer case has been trouble free, suspension links a bit bothersome from wear. Tires last 130,000-160,000 km. Brakes are OK but require constant work.
Everything still operates, all electric things, seats, windows, lights but that may be from corrosion protection because like Datsun these vehicles are rust buckets. The paint job is good.
After 20 years will it still be around? I think so as long as I keep working on it, and I'll never get used to replacing that ****dam # 6 plug. As far as I am concerned it is the worst job for me, not changing brakes, tie rods, ball joints but getting my body up to where I can see and manipulate socket, extensions and ratchet to undo then install a single plug.
It could be worse, I could have to jack up the engine like other cars I'v owned.
My next vehicle will probably be a 2 or 4 cylinder or another diesel, but then they have their issues.
