Caramrodttz »
https://forums.nicoclub.com/caramrodttz-u267294.html
Sun Oct 16, 2016 6:31 pm
hello all, i have a 91TT with 120k miles. ive known ever since i bought the car that i needed new bushing. i decided to put that off to repair some other things first; fuel filter, fuel regulator, heater core, clutch, tires, coolant hoses, fuel hoses, spark plugs and timing belt. now that the car is running much better i feel its time to upgrade the ride quality. i notice i get some bump steer and the back end bounces alot, mostly on bad roads. ive been under the car a lot and noticed the bushings are dry\cracked. i was hoping to get some info and some help on which brands and overall what i need for what i want for the car. which is mostly canyon runs with some track use. i saw a set of bushings from energy suspension that seems to have basically everything i need. just not sure if i should get that or a different brand, and how hard it is to do. i was also thinking of some coilovers. not sure which brand i should go for though. if anyone has had some experience with energy suspension or replacing bushings, your help would be appreciated.
