Larz »
https://forums.nicoclub.com/larz-u216291.html
Tue Oct 29, 2019 5:06 pm
I'm still suspicious of a possible cause / effect relationship that starts with significant oil burn and ends with timing chain trouble. Lots of different engines burn oil and it's not necessarily a cause for concern. However ... When timing chains start to stretch or loosen, they result in oil burn and if the chain is not replaced, it can continue to loosen and eventually fail. I can't prove it, but I just have this suspicion that the timing chain recall is the result of poor design of the timing chain and THAT explains why some 5.6 engines burn lots of oil. It might be interesting to compare oil burn before and after the timing chain recall is performed. If the the oil loss decreases after the recall, that supports my suspicion.
a** far as what to buy if you sell your M56? The only choice that comes close to the level of performance, quality, and reliability would be Lexus. Specifically, the 430 or 460 years. The LS models can be pricey for maintenance, but they very rarely need actual repairs. They also have a higher resale than Infiniti, so it might be slightly harder to get a used one at bargain prices, but my service rep came from Lexus and he says it was not unusual for LS 430/460's come in for oil changes with 200k miles and they almost never came in for anything but maintenance items. He actually drives a 460L with 160k miles and he has never done anything but fluid changes.
