Time to replace display screen???
Alffie
Car: 2010 Infiniti M35
Is there an aftermarket one that can be used or does it have to be an OEM one?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I don't know of anybody making aftermarket replacements for those. It's a stand-alone display unit, unlike most other models where the display is integrated.
Alffie
Kinda figured that out when I was searching and nothing came up :) . Sucks big time tho :rolleyes:
Reason: EDITED
dannyg
Car: 2007 Infiniti M35x
Yes it does suck. I am trying to replace my stereo unit as well. After disassembling everything I understand why. It is not a simple plug and play hook up. I tried the kunfine android 10 unit on amazon. Came with incorrect wiring harness and ZERO instructions. I am going to try to wire it myself but am hesitant and will probably buy a good brand if I have to do all that.
Alffie
dannyg wrote:
Thu May 25, 2023 10:40 am
Man I missed the old days where you can just buy the wire harness and go. These new cars are too technical :biggrin: let me know how it goes. Hopefully all goes well :dblthumb:
Reason: EDITED
Alffie
I noticed this a few wks ago..it was much more than that. Almost looked like a foot on a pedal :biggrin: .
Reason: EDITED
VStar650CL
Technical Expert
Alffie wrote:
Thu Jun 01, 2023 9:53 pm
I noticed this a few wks ago..it was much more than that. Almost looked like a foot on a pedal.
Dead pixels in the display. Some of those have ZIF (Zero Insertion Force) connectors with flat-ribbon cables connecting the display to the mainboard. If you pop the back off the cluster and find a flat-ribbon, there's a good chance cleaning the cable and ZIF with alcohol and re-seating the cable into the ZIF will fix it.
Alffie
O ok, thanks. It went away on its own🤷🏼‍♂️
VStar650CL
Technical Expert
Alffie wrote:
Fri Jun 16, 2023 7:43 am
Provided it stays that way, that's always the easiest repair.
:chuckle:
Larz
Car: 2019 Q70-L RWD
You can probably find a used display screen on Ebay. They come form salvage cars and they usually guarantee them.
Alffie
Larz wrote:
Sun Jun 18, 2023 7:46 pm
I've seen some, but I'm kinda skeptical. Maybe one day I'll get one
