deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Mon Apr 12, 2004 6:30 pm
1. Noted in various places to be .047" crushed, ones i have measured (stock crushed) have measured closer to .040".2. ka24de 45cc, ka24e 65cc 3. 247mm (9.72441")4. De pistons roughly 11.2-12cc dish volume, Late ka24e pistons 2cc dish, early ka24e pistons 2cc dome.
for 8.1 CR in ka24de you will want pistons with ~28 cc dish volume using stock compression ht for piston (34mm).
Thats a major dish, it would be better to go with pistons with much lower compression ht. So there are quite a few combos to go with, something like a 31mm compression ht, 8cc dish would work. This is for 8.1-8.3:1 in ka24de
If its a ka24e, you will need pistons with stock compression ht, and a 9-7cc dish. Or flat tops with a 32.5-33mm compression ht.
This is only a basic guideline, there are many different combos in between.
