mike240sr wrote:The is here for the SR20 swap to get under way. I wanted to post a questions on what all of you think are the best, or the best deal parts to get at the same time. I am planning on getting a:
- Front Mount intercoller- Downpipe- High flow cat- Full cat back - BOV- boost controllar- Fuel pump- Intake- Clutch
What do you think are the best parts in the catorgies.and if you think there are anyother parts you think i should let me know.
Modified by mike240sr at 9:54 AM 1/15/2005
forget about boost controler for now, getting the swap done right and make it run reliably is your first priority.If i were you, i would defnitely throw some $$$ on the valvetrain (springs, RAS) since SR is known for crappy valvetrain
