GTR PrYdE »
https://forums.nicoclub.com/gtr-pryde-u29428.html
Sat Feb 14, 2015 10:17 pm
A small budget, i'm afraid will only get you in trouble, since two very rea lpossibilities will occur-
1. You run into weak points once you get the car going which may leave you with a broke down ride and no budget
2. You buy alot of parts but end up overlooking extra expenses that your budget won't cover.
I would say a comfortable budget going turbo on a 240 should be ~3500-4000, after all, you said long term daily driver. The turbo triangle says "fast, cheap and reliable, you can only choose two" and going turbo automatically fills the "fast" part.
Not sure how good the stock fuel pump is good for, but if your old stock pump dies (a $80-100 replacement part) during wide open throttle, you can pretty much guarantee a blown engine. A FMU (fuel management unit) is supposedly a cheap and reliable way to overwork your factory fuel system, but I would advise a decent work over like I suggested to keep things reliable and ready for future upgrades.
I don't know what a stock clutch will hold power wise, but be prepared to replace it regardless (I.E. budget for it) since a little abuse with turbo power *could* roast it.
It can get expensive on these aging cars, since you could end up replacing alot of parts that are basically at "end of life" anyway and will really start to show their age once you put some real power through the car.
No, I wouldn't worry about an oil cooler, save that for road racing or similar that has your oil temps (aftermarket gauge needed) asking for cooling.
If I had a 2k budget, I would do all the maintenance things (such as worn out suspension or clutch, any leaks or smoking issues, better exhaust) to the car first, then keep saving for a intro turbo setup like I linked.
