who is joe?yodawill2000 wrote:Find an infiniti dealer or order it from joe ,
Does that also apply to 93's that the timing belt was changed since 94? Or are 93's not able to use the Kevlar belt? I know mine was changed at 60k miles, probably around 2002.yodawill2000 wrote:I might add ..When I got my J it was at 124 K and was freaking thinking about the timing belt .Then one day I looked at the plate just under the leading edge of the Hood it was imprinted with "Timing Belt Replaced a 62K"
94's use a kevlar belt thats good for 105 K i believe .
well I got 138k miles, so I guess I will wait a bit longer. I will look at the model this weekend of the belt and see if I can verify it is the newer kevlar belt.gr8scott72 wrote:Well, we got our 93 in Sep of 05 I believe and it had about 170k miles on it and I don't think the belt had ever been changed if that gives you an idea of how long it will last.
Don't worry, I've had it changed since then. I found an independent infiniti/lexus shop that did the whole job for just under $400.
