NODES wrote:change them yourself and save money.
Search the Versa Technical manual on how to replace them.
I googled it and found it on some other forum in the past. It is too big to email.Driving Instructor wrote:I tried to look up the Tech Manual... is it online or on this Forum??
Please and Thank you!
intake or the throttle body?blockmachining wrote:To change the spark plugs, you have to remove the intake. That is one of the reasons why the cost is higher than what you might normally see.
I googled this, sounds scary. Yet it does not make sense.Driving Instructor wrote:anyone has pictures........? I tried looking online and I could not find anything. Is this a job only for the dealer???
Let me know please.
Thank you,
HEAR THIS; TO CHANGE SPARK PLUGS, THIS IS THE PROCEDURE.1) DRAIN COOLANT. YES DRAIN THE COOLANT.2) TAKE OFF THE ENGINE COVER.3) TAKE OFF THE INTAKE MANIFOLD. YES THATS CORRECT4) TAKE OFF THE COIL.5) CHANGE PLUGS AND REASSEMBLE. WHEW BY THE WAY PLUGS ARE GOOD FOR 105,000 MILES.
No more waranty. Trust me, i was all about the waranty but it ran out at 160 000 kms (i did buy the extended bumber to bumber and it was worth it!!!! But I can do lots mechanically but it helps when you can get some "support" on line..lolalonsorules8 wrote:If your not mechanically inclined you should go to the dealer to have the spark plug replaced.
I for one will bring my car to the dealer just due to the fact I don't want to mess with the life time warranty my engine has.
alonsorules8 wrote:I totally understand that. I love how this forum is very helpful to all the members.
Here is the pic of the procedure:
Plug type : Iridium tippedMake : DENSOPart number : FXE20HR11Gap (nominal) : 1.1 mm (0.043 in)NODES wrote:Do you know what the gap distance should be ?
can you bring your own in?Driving Instructor wrote:Off to the dealer I go............
I looked into it a bit more and said screw it.
But the dealer said the plugs are like 30 bucks each.... Yeah 30 bucks..
All together it will cost me around 250 to have 4 plugs changed........
RETARDED!!
Yeah I guess you cannot complain, that car is making you money right? Sometimes you have to give back a little to take a lot backDriving Instructor wrote:looked around and can't get them yet..
so...... I am looking at it more like this...
This is the first out of pocket expense for me and it's at 165 kms...
And I am getting my CVT transmission checked for 30 bucks..........
but I am getting a sweet deal on an OIL change: 12.50 (the price of an oil change when they opened up 40 years ago..lol)
It's a rip off!!! Have you tried another Nissan dealership around if there is one? I bought mine(NGK LZKAR6AP-11) from Nissan Dealer ship for AU$24 each and I did it myself. Didn't even have to drain coolant.Driving Instructor wrote:Off to the dealer I go............
RETARDED!!
