Time to call on the nico GODS for replacment help
SA_S13_0201
Car: 1990 Nissan 240sx
Well finally got a little money to replace some needed parts on my s13. I need to be pointed in the right direction to replace a couple things.
-Wheel bearings front and rear ( only need the front but hey why not?)-windshield-for some reason my dash lights dont work. they havent since i got the car 5 months ago.
much thanks.Jerm
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Buy oem wheel bearings or do a 5 lug conversion right now.
Get your windshield replaced at a reputable place.
Check fuses i guess for the dash lights? are they ALL out or just a few?
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Dash lights are probably because the TCU is shorted. Common on s13s. Its the white box located behind the driverside kick panel.
OM3GA
Yeah true story
SA_S13_0201
well i got about 500 for the 5 lug think i could make it happen? and as for the windshield isn't there a way i can replace it? i mean ive replaced a 68 mustangs glass is there a certain way of doing it? and as for the gauges ive checked all the fuses and there all fine. ill check on that white box tomorrow is there a way i can test it other then replacing? i heard its a common problem for s13 if you install an aftermarket stereo in there.
240agsx
Car: 240 sx project
well you could possibly do the windshiels yourself tho, i think its relatively cheap for you to change the windshiels about 80 to 100 bucks and thats with new glass and installation; just my opinion. My windshield is cracked in the top right for some reason its cracked in a circular motion i think im just gonna put a sticker over it
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
If you pop the TCU apart you will see the burnt path if it is bad
crakin
Car: 1996 240sx s14, 2008 Chevrolet silverado crew cab,
2011 Suzuki gsxr 750
Didn't a guy do a writ-up of how to run a bypass on the circuit board not too long ago. Or am I mistaken, Sir. If so, only if your TCU is fugged up, you may be able too cost effectively. hope it's not though payne in the arse
