WizardBlack »
https://forums.nicoclub.com/wizardblack-u76567.html
Thu Sep 11, 2008 1:18 pm
Most big turbo people go with speed density to eliminate any MAF, so that's really not a big issue if you use a standalone. I'd look at Wolf3D or AEM for a sequential ECU.The block is aluminum, so it already has sleeves. You really don't need to install new sleeves unless you want to (or have to) bore it way out. Neither of which is really going to apply to the VH45DE motor.AFAIK, Mazworx has custom designed CP pistons already figured out that uses a standard chevy rod (of some sort), so you can get forged rods pretty cheap. Contact Cometic for some MLS headgaskets. They are great about getting stuff custom made (or already having it). The only thing left is head studs and maybe a head port job. A custom plenum is pretty straightforward assuming you take some time to study them and know how to TIG.
