rsiwicki »
https://forums.nicoclub.com/rsiwicki-u13199.html
Wed Jan 05, 2005 8:05 pm
Well....here are 3 new runs from running at Moroso tonight. I would have got in more runs but two cars broke down separately on the track closing it down for a while until it was cleared....including a SC Mustang that blew his engine right at the end of the 1/4 because he screwed up on the launch and was trying to over compensate at the end of his run (smoke everywhere)....
Moroso 1/5/05 95Q45T With Headers/Exhaust/JWT ECU/HomeDepot AirIntake Special With K&N Box Filter/3.54 Gears & 147,000 miles
........#1-Man...#2-Man...#3-ManR/T.....0.350....0.034........0.63160'.....2.207....2.170........2.191330'....6.178....6.125.......6.1721/8.....9.349....9.300........9.366MPH....78.10....78.05........77.741000'..12.057...N/A..........N/A***The 2nd lane 1000' timer was not working1/4....14.333...14.282......14.363MPH....99.73....99.77........99.56
All is exactly the same as this summer in the July heat....temp was forecasted to be about 71 tonight with a lot less humidity than in July. I can see that the heat factor really takes the HP right out of the car as 0.3secs for about 13 degrees cooler and less humidity makes a huge difference. I will run again when/if it ever gets into the low 60's to see what the beast has hiding in cooler weather. Just maybe my original goal of breaking 14.0 1/4 ET is still somewhat attainable if it is cool enough.
I screwed up on the last run #3 and held the 1-2 shift way to long becuase I felt the car all of a sudden stop accelerating as I hit the 7,300rpm rev limiter. I do have the JWT TCU, but screwed up and put in the wrong TCU the other night and have not had a chance to switch it back out. I have 3 different TCU's....a JWT, 93 TCU, and my original 95 TCU and me and a buddy were trying out some different combos the other night and I screwed up and reinstalled the wrong TCU in the dark.
There were several nice cars there tonight....3 Vipers (one 2005 Viper) couple new C6's & older ZO6 (the new C6 was just as fast if not faster than the 3 Z06's all totally stock....the ZO6 guy was pissed, two E55's which are just plain awesome...ET of 12.5 totally stock out running the new C6. I had two comments again asking if the car was FWD after seeing the plenum. All were very impressed with the Q and how such a big car could move so quickly. The was an older Ford Lightening that the guy could not believe I ran that fast as he was only running mid 14's. Below are some older 1/4 ET's for your references. I think that the cost of the headers has finally paid off giving me an extra 0.4 secs off my 1/4 times.
I am going to add an enclosed (totally sealed) Pop Charger for the next time I run to see if that helps things out and make sure that I have the JWT TCU so I don't have any more guess work on when so shift screwing up a good run by hitting the rev limiter....
Moroso 7/3/04 95Q45T With Headers/Exhaust/JWT ECU/HomeDepot AirIntake Special With K&N Box Filter/3.54 Gears
........#1-Man...#2-Man...#3-Man..#4-Auto...#5-AutoR/T.....0.708....0.107....0.0990...0.118...0.66060'.....2.291....2.272....2.290....2.306...2.345330'....6.359....6.334....6.354....6.382...6.4331/8.....9.575....9.547....9.566....9.599...9.649MPH....77.12....77.63....77.21....77.08...77.611000'..12.317...12.297...12.307...12.343..12.401/4....14.618...14.601...14.610...14.656..14.715MPH....97.33....96.48....96.53....94.96...96.34
........#6-Man...#7-Auto...#8-Man.....#9-Man R/T.....0.354.....0.549.....0.698......0.49460'.....2.378.....2.331.....2.339......2.371330'....6.455.....6.386.....6.410......6.4341/8.....9.664.....9.605.....9.647......9.643MPH....77.92.....77.49.....77.35......77.851000'..12.417....12.357....12.408.....12.3971/4....14.721....14.676....14.740.....14.707MPH....96.46.....95.46.....93.15......94.93
Moroso 6/30/04 95Q45T With Headers/Exhaust/JWT ECU/HomeDepot AirIntake Special With K&N Box Filter/4.08 Gears with 140K miles
Run.....#1-Drive....#2-Man Shift....#3-Man Shift...#4-Man ShiftR/T.......0.797..........0.892...............0.309..............0.21060'.......2.295..........2.303...............2.322..............2.277330'.....6.354..........6.350...............6.444..............6.2781/8......9.617..........9.594...............9.767.............9.521MPH.....76.09........76.43.................74.36..............76.211000'..12.436......12.387..............12.612...........12.3301/4.....14.814......14.757...............15.012............14.709MPH....93.55.......93.56..................93.34.............93.37
Just for comparison...here are some other 1/4 times from me and other NICO members.
Greg's (AzHitman's Car with 4.08) ET'sR/T: .17460': 2.541/8: 10.2681/4: 15.123MPH: 94.48
Oxs1 ET's (1 month ago)........Oxs1 ET's (Oct. 2003)R/T: .651.................................0.83360 FT: 2.580...........................2.467MPH: 72.93............................73.64ET: 10.266.............................10.058
rsiwicki Runs - 1st Run (Stock 4/15/04)60' = 2.4330' = 6.81/8 = 10.3 @ 71.3mph1000' = 13.31/4 = 15.7 @ 88.0mph
rsiwicki Runs - 2nd Run (Stock 4/15/04)60' = 2.4330' = 6.91/8 = 10.3 @ 71.0mph1000' = 13.31/4 = 15.8 @ 88.2mph
FastLane's Runs....96Q45 - Stock 6/30/04 Moroso Speedway
!st Run..... R/T.. 1.153 last Run.... R/T... .67360'... 2.511 60'.... 2.550330.. 6.981 330... 7.0111/8... 10.49 1/8... 10.46mph.. 70.92 mph... 71.861000.. 13.47 1000... 13.401/4... 16.006 1/4.... 15.888mph... 88.13 mph... 90.06
Modified by rsiwicki at 1:59 AM 1/6/2005
