joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Wed Feb 07, 2007 9:39 am
Ok, I'm doing some research...I wanted to post this on the G35 board as well...
The OEM size for the G35 with 19's is
F 225/40R 245/40
If you multiply 225 * .4 you get 90...which is the side-wall height, correct?
Now with another tire, say 255/35; multiply and you get 89.25, almost equal to the OEM side-wall height, but 30mm wider...Correct?
So, this new tire should stick out of the rim more than the OEM tire, but be almost identical to the side-wall height, thus not affecting the VDC???
Can the rim handle a tire that is 30mm wider?
