Time for Tire's
curtiscr87
Car: 2008 Infiniti G35x
2011 Nissan Sentra
I have a 04 G35 coupe non brembo, my tire sizes are p225/50r17 front and p23550r17 rear im wondering if anyone has put a wider tire on the stock rim than 235 with any problems
Im looking at getting the hankook VR's does anyone have experiance with these?
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
I've yet to see anything wider on stock wheels. You would probably want to go with wider aftermarket wheels for that.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Sorry, no help here.Have Yoko S-drives on my stock 17s.....So far, love the yokos!
audtatious
245's will work fine on 7.5" width rims.
spuy767
Car: 2006 G Coupe 6MT (Daily Driver), 1987 Buick Grand Nat'l & 1964.5 Mustang (fun)
You can go wider by about 30 over stock before you run into scrubbing problems, but you need to make sure that you do some tire math to get the same revs per mile or you'll futz with your speedo. I don't have any experience with what the computer will do if you change the RPM of the tire.
joe603
Car: 2014 Durango R/T
Another vote for Yokohama S-Drives...I have them on my coupe. I also had a set of Toyo Proxies...I think I like the Yoko's more.
Joey666Crack
Car: 06 G35 Coupe
I'm running 245's in the back. 06 Coupe.
pfarmer
Car: 2008 GXS with technology package
curtiscr87 wrote:I have a 04 G35 coupe non brembo, my tire sizes are p225/50r17 front and p23550r17 rear im wondering if anyone has put a wider tire on the stock rim than 235 with any problems
It looks like you could go to 255/50/17s on a 7.5" rim as far as the tire/rim are concerned (no lower profile however) without regard to any other factors such as possible rubbing or speedo issues. Speedo would be off by almost 3%. Recommended rim width of 7" to 9".
A 245/45/17 (no lower profile) will put you at about a 2% error on the speedo but also puts you are the recommended bottom limit on rim size of 7.5" to 9".
If you go to 18" you could go with a 255/40/18 with less than a 1% speedo error but you need 8.5" to 10" rims.
Non of these size address anything other than tire and rim size recommendations and not things like rubbing.
The biggest item however is brakes. I would not do anything wider without consideration of improvement of brakes, especially with the stock wheels. Aftermarket wheels may allow a lighter wheel but may yield a heavier tire with a greater rotational mass sitting at a greater distance from the center axis.
Perry
SVTCOBRA
pfarmer
These are not figuring in the recommended rim widths for various size tires although you do get the offsets, etc.. The calculator does give the ability of matching up the speedo.
What really is necessary I believe is to follow the tire manufacturer recommendations for rim width which from what I have seen tends to land within about 1/2 inch between manufacturers. To be on the safe side, especially consideraing possible tire replacements in the future I would select rim widths based on the center recommendation for the target tire.
For example if a tire gave a rim width range of 7-9 inches I would lean towards an 8. If another tire manufacturer gives 6.5-8.5 inches or 7.5-9.5 inches you are still sitting pretty close to the same centerline area of what is considered acceptable rim widths. Otherwise one may need to select based on what is simply available in the way of tires instead of what is desired in the way of characteristics.
Perry
TurboDurbo
Car: '07 Infiniti G35 Coupe 6MT
Just purchased a set of HANKOOK Ventus V12 evo K110
They also came with a $50 rebate got all 4 for $606
Stock 2007 19" sizes.
2 X 225/40ZR192 X 245/40ZR19
I like them so far haven't tested them at the track yet.
audtatious
I'm in a similar boat. I put Hankook Ventus V4es's on the wifes G35s a month go. So far, no complaints.
