Time for some more go!
jrd450r
Car: 1990 RB25DET S13
I was very lucky this past week and got a chance to be on Pass Time on Speed channel and took the win! I got $2000 for winning, I would like to save a bit of it but I also want to upgrade my car. I would really like some suggestions from you guys if you don't mind. Right now I have a basic swap with motor mounts, drive shaft, FMIC, Walbro, and adjustable FPR. Where my plans are to go with this car is to do a Holset HX35. Now to do that I am going to need injectors and something to tune with. I would like to go with a mega squirt set up but my question to go along with that is, do I need to tune my timing when putting this turbo on or is it only going to need fuel tuning. I can use the MS to control my EFI and use the stock ECU to control the spark. Any one have any input on that? What injectors are you guys running also, I am going to guess I need somewhere in the 550cc area. Is there any cars that I can get them off of and make them work on the RB25 application like for say the RX7 injectors? And what else am I going to need to get this thing going? Thanks for any help in advance!
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Well done! Congrats on your win.
Unfortunately, I'm not the guy to answer the rest of your questions.
WhatsADSM
Car: 1998 240sx
Congrats on the win! Yes you will need to tune the timing tables when you replace the turbo.
Have you ever thought of going with a Nistune setup? It would require you to get a VG30DETT ecu and make some pinout changes, but that would give you the best tuning solution for not very much money.
240slidekat
Car: 240sx, 280z, gsxr1000, m3
as far as injectors, im going to be upgrading my 550cc to 750cc, if you want i can sell them to you for a pretty good price.
meet07
Car: 89 180sx rb25det
i to wanted to get nistune but im starting to like what i have read about greddy emanage ultimate. Do you plan on using the hx35 with the factory manifold?? i too have the hx and cant seem to find a twin scroll t3 manifold with external gate.
congrates
WhatsADSM
Car: 1998 240sx
dftsilvia wrote:y the hell would u run 2 ecu's when the megasquirt can tune both timing and fuel?
put the ms in and take it 2 someone who can tune it b4 u mess ur stuff up
I dont think MS has enough outputs to run sequential fuel injection and ignition in either direct fire or waste-spark.
You *might* be able to get it to run some sort of a multiport or batch fire injection and wastespark, but I'm not sure. MS is pretty limited on outputs.
