Unless you know this for a fact, it would be better not to give "undue" information. I have been running cross-drilled rotors for over 3 yrs and have NEVER had the slightest issue with them...EVEN under extreme stress. So...the moral is...don't believe everything you read on websites.Blazingwolf wrote:DOn't get drilled rotors... they crack under stress.
And just out of curiosity...where/from who did you get your rotors? I dont have a "big brake" upgrade...only the OEM size, but they are Brembo X-drilled. NEVER had any problems under ANY circumstances, nor ANY signs of the slightest crack. The reason I'm asking where you got your set from is that alot of times you get what you pay for. Not saying you did, but if they were from ebay or someplace like that, then I wouldnt be so quick to stand up and be blaming the rotors.Blazingwolf wrote:Big brakes Kits like brembo and such.. have thicker rotors and have a larger surface area, they dissipate heat better so unless you go extremely high speeds they don't crack
LOL...my bad dude, just trying to make a point.Blazingwolf wrote:ouch im hurt
