dbaxRonin »
https://forums.nicoclub.com/dbaxronin-u181868.html
Mon Nov 11, 2013 6:11 am
You can't tell by looking if a wheel is balanced. The weights counter-act any uneven load as the wheel spins. You can only really tell if a tire is out of balance when you drive it, typically at higher speeds (50+, depending on how out of balance they are). The car will start to noticeably rattle and shake at a specific speed range.
Think of what would happen if you tried to spin a hoolahoop that has one half filled with concrete. As the unfilled side came around your waist, the weight of the concrete would make the outer end fall to the ground. But, if you filled the other half with the same amount of concrete (and you were Superman) you could get it to spin around you without one end or the other falling to the ground.
Your tires should be balanced by the installer whenever you get new tires put on. They may not always be necessary but they will always check it. The shop uses a balancing machine that spins the tire at a high speed and measures the amount of weight needed, and tells them precisely where it needs to go. If you don't notice any issues when driving now, it could be the missing weight you noticed was a spot where an old weight was removed the last time the wheels were balanced. In any event, if you are getting new tires, they should re-balance them for you.
