Yes, this is true. Right on the rubber intake pipe on the left side its about a 1" extension. Yeah like Jesse says, if that bung on the i/c pipe is on the drivers side of the core, I'd use it to mount BOV/ Recirc. valve. The only reason I didn't use mine is because it was on the passenger side and under the pipe, so there wasn't enough clearance for a valve. You'll have to get someone who can weld alumuinum to mount it for you though.BaliLover wrote:I believe that the stock rubber hose thats behind the MAFS already has a place for a recirculating valve to vent into.
